phono to banana/speaker wire adapters
Discussion in 'Cables & Switches' started by shuggy, Mar 12, 2005.
  1. shuggy
    shuggy
    Feb 12, 2005
    422
    +12
    I am trying to connect a standard phono jack to the standard speaker outputs(red black) from my yamaha rx750 amp. This is required to allow my amp to drive my Loewe TVs speakers as my central speaker. They have a product specific 9 pin adapter at the TV end with a phono at the input end. I amongst others on AV forums are looking for a suitable adapter- Any Luck?
    shuggy
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Are you sure that your TV speaker is able to handle the power output of the Yamaha ?
  3. shuggy
    shuggy
    Feb 12, 2005
    422
    +12
    it is designed to take the output of the concertos system, how could I check
  4. Peridot
    Peridot
    Aug 24, 2004
    2,911
    Newport, South Wales
    +285
    Shuggy,
    I've got some phono sockets with short flying leads that you could connect to the Yammys output terminals.
    Nothing fancy, but I'd be happy to post you one if you PM me your address.
    ________________
    Dermot
  5. shuggy
    shuggy
    Feb 12, 2005
    422
    +12
    Rated audio power 2 x 15 Watt / 6 Ohm
    Audio music output 2 x 40 Watt / 6 Ohm
    Speakers 2 closed boxes
    Tweeter 2 x 20 mm
    Bass 2 x 75 mm
    Does that sound incompatible with a 100w output yamaha 750?
  6. arin
    arin
    Peridot i hope you dont see this as me taking the **** however i have been loooking for what you have for some time, would you be able to give me 2? or tell me how to make them?? cheers
    "I've got some phono sockets with short flying leads that you could connect to the Yammys output terminals."
  7. Peridot
    Peridot
    Aug 24, 2004
    2,911
    +285
    Hi arin,
    Have replied to your other thread. I'm not sure that this is what you need.
    ____________________
    Dermot
