Phono Stage
Discussion in 'Hi-Fi Stereo Systems & Separates' started by rhinoman, Jun 30, 2003.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    My new myryad amp doesn't have a phone stage so I need to get an offboard one to go with my project debut turntable. Its not used all that much but it would be nice if it worked.
    Anybody got any ideas what to spend and on what?
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    What sort of phono stage are you looking for...moving magnet or moving coil...or one for both possibilities...and do you have a specific cartridge in mind.
    There are several excellent phono stages out there,and an idea of your price range/requirements would be useful.
  3. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    68
    Leicester
    +56
    I'm currently using an old Rotel pre amp as a phono amp/audio input switcher with a Project Debut II. If I decide to sell the amp then I'll get a cheap phono board on ebay (they go for about £5-£10). However, I'm inputting it to a mini system only. I'm guessing your amp and speakers deserve something better so you might want to try Project's own amp which is £40 new or about £25 SH.
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I think mines a Debut II, but I'll have to check the manual, same applys to the type of cartridge but the whole thing only cost about £135 so something for about £50 seems plenty.
    Haven't bought a record in years so its only for those nostagic moments from my collection from years ago. Its all been CD since then.
    Sounds good, I'll have to check it out.
    Anyone got one spare??
  5. steve1056
    steve1056
    Apr 20, 2002
    384
    Reading
    +5
    Hi John,
    Hope the new processor is as good as you expected. By coincidence, I bought a phono stage the day after you came round to pick up the Myryad. Went for a Project Phono Box (the standard one, not the SE). Cost £45 from Audio-T. For the few times I play LP's nowadays, this sounds good enough to me on my Linn Sondek/Meridian set-up. It can be configured for MM and MC cartridges by positioning some jumpers inside (the default is MM).
    Cheers,
    Steve
  6. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Hi Steve,
    Well if its good enough for you....it'll do for me.
    The MDP500 is away for the G6 upgrade, should be back in the next couple of days with a bit of luck but I did spend an hour with it and it seemed great so far.
    Regards
