phono stage
Discussion in 'AV Receivers & Amplifiers' started by blim, Jun 27, 2004.
  1. blim
    blim
    i've recently bought an arcam avr200 and realised i need a phono stage. any advice would be helpful
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Then go and buy one :D
  3. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    you can buy an outboard phone stage from your local hi fi store.
    Works a treat.
    Richer sounds do a vivanco stage for £19. (i think)
  4. bobbypunk
    bobbypunk
    What level of turntable?
    up to £300 consider Nad PP2 @ £50
    £200 + consider Project PhonoboxSE @ £125
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    What type of cartridge MM or MC and how much do you want to spend
