Phono Splitter for 2 subs
Discussion in 'Subwoofers' started by john87, Aug 18, 2002.
  1. john87
    john87
    If you already own a phono lead is there a way of splitting it for 2 subs while still using the original phono?
  2. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    You can buy inexpensive short splitter leads: a flying socket to two plugs. You'd then need a phono-connector and longer phono-phono lead to connect up the second sub.
    Bert
    www.bertcoules.co.uk
  3. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    There are several ways of achieving the same ends.A 'Y' adaptor .1MX2F that you can plug into the amp socket will give two outputs from the original one. CPC do one for less than £1.
    Leads,as Bert also points out,are available ie 1Fx2F will allow your existing phono lead to be taken off by another two singles.
    If you think a 'Y'adaptor will be of help to you PM me your address and i'll send you one *If i can find it :) *.
