Phono Setup Help.
Discussion in 'Hi-Fi Stereo Systems & Separates' started by uk_saw, Apr 19, 2005.
  1. uk_saw
    uk_saw
    Nov 10, 2004
    10
    Hi Ladies and Gents,
    I am unfortuantely not very wise when it comes to setting up hifi systems and I am hoping one or two of you may be able to give me some help.
    I have been given a second hand rega planar 2 and I wish to purchase an amp and some speakers (i think) so that I can play my 80-90's britpop 7's.
    I currently have the all-in-one-box Denon DVD,5.1 amp system as my music centre. I have tried plugging my planar into the video one component inputs but it does not generate any sound (should this work?).
    As this did not work I am assuming I will need a seperate amp and speakers to hook upto the phono and would like some suggestions on what I could buy for the 700-1000 mark. Any advice or suggestions most greatfully recieved.
    also is there a good way to turn vinyl's into mp3's?
    Steve
  2. daveb975
    daveb975
    Oct 25, 2002
    4,328
    103
    London
    +368
    What Denon have you got - a DHT500?
    Most of these systems do not have a phono input, so you will need a phono pre-amp to plug between the TT and the system.
    Something like the Pro-Ject Phono Box for about £40 should do the job - cheaper than a new amp and speakers anyway!
  3. uk_saw
    uk_saw
    Nov 10, 2004
    10
    Hi Dave,
    Yes thats the one I have. I will check out the project box.
    thanks for the advice, certainly sounds cheaper :)
  4. SKA.face
    SKA.face
    I would go for a Creek OBH phono stage,works superbly with the Rega decks,it cost about £180.The rest or some, you could spend on improving the Rega deck.
  5. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I have a Musical Fidelity X-LP phono stage between my Rega Planar and the amp; very nice; not made any more but these and other phono amps show up on ebay all the time.
