Phono (RCA) cable leangth to Sub from A-V Amp?
Discussion in 'Subwoofers' started by iMan, Dec 11, 2003.
  1. iMan
    iMan
    Mar 30, 2003
    34
    Just in the middle of installing an Home Cinema Projector system. My A-V Amp is 4 metres away from the Bass Subwoofer, for me to run the phono lead from the Sub to the Amp routing it properly around the scirting boards will come to 14 metres.
    The man at the shop told me that if I used a Phono cable that long it will loose amperage/power/quality? something like that anyway.
    Is it okay to use a Phono lead that long? has onyone experienced problems with such a long Phono lead from the Amp to their Sub?
  2. BenPremium
    BenPremium
    Nov 23, 2003
    331
    16
    Well, I don't have that much hi-fi knowledge but my physics knowledge would lead me to believe that you will always lose a tiny bit of signal strength from the restistance of the wire but surely this is going to be negligible if the current is extremely low (it's only a signal). I guess interference would be more of an issue, especially if it's an unshielded cable running round the skirt where your power cables may be.
    I have a 4 metre cable (1 + 3 metre extension) and have no problems.
  3. sticker
    sticker
    Jan 14, 2003
    1,153
    36
    Sydney, Australia
    iMan,
    I use a 2 cables on my subs, one of which is just over 10 metres, with a couple of joins in it. as far as my ears are concerned there is not sound degregation.
    Read the Beekeepers thread on the cables section of this forum, it mentions there about sub woofer cables. Alternatively look at Mark Grants power buy in the power buy section. I use Scorpion cables and they are very good.
    Regards
    John
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,136
    Cumbria
    +1,276
    Cable length isn't the problems per se but the ability to drive it, with modern well buffer outputs 14m is a walk in the park, R loss is minimal just use the right cable :)
    I have never tried it but I suspect my Tag would have no problem with 100m....of the right cable ;)
  5. iMan
    iMan
    Mar 30, 2003
    34
    I was just going to pop down to Currys and buy 2 x 6 metre jobs for £5.99 each, will they be okay, if not please give me a make and a supplier were I can get one
  6. bob1
    bob1
    Nov 7, 2002
    4,354
    Sheffield
    +131
    You could make your own ,i did 10m long.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    I man see mark grant in powerbuys forum, he will custom you a stonker of a sub cable!
  8. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    Having read The Beekeeper's lengthy thread in the Cables forum which includes a section on subwoofer cables it would seem that the specifications that he mentioned are exactly those used by Mark Grant in the cables that he makes up and sells via the Powerbuy forum.
    I believe that there is a special powerbuy price coming this weekend for his top quality subwoofer cables.
