PHONO input on Sony STR-VA555ES
Discussion in 'AV Receivers & Amplifiers' started by iwatkins, Dec 26, 2002.
Tags:
  1. iwatkins
    iwatkins
    Hi All,
    On the above amp. I have a pair of analogue inputs specifically labelled PHONO. The manual refers to this as somewhere you can connect a turntable. Fair enough. However, it doesn't say whether these inputs are expecting the singal to be pre-amplified or not.
    Anybody know ? I'm looking to buy a turntable as all my vinyl ain't dead yet, but need to know whether I'm looking for a turntable with the pre-amp or not.
    Ian
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,905
    71
    50 Rue St Georges, Paris.
    +32
    Sony STR-VA555ES Phono input does not require a pre-amplified signal, an ordinary turntable will suffice.
  3. iwatkins
    iwatkins
    Thank you. That opens up the options available to me.
    Ian
  4. rob_w
    rob_w
    make sure the turntable has a moving magnet cartridge - moving coil ones will need a step up transformer still..(unless it's switchable on the amp)
    Rob
