phono connects between power and av amp
Discussion in 'AV Receivers & Amplifiers' started by Geoffc10, Nov 25, 2001.
  1. Geoffc10
    Geoffc10
    I've just ordered the Rotel 985 power amp which i plan to use with my sony 1070 amp. What kind of phono connect do i need for the centre channel. I take it I cant use 2 phono- phono for a centre channel as its only one socket?
  2. Guest
    You will have to use "half a pair" of interconnects...ie just one lead, a bit of a waste as you have to buy them in pairs!
  3. Geoffc10
    Geoffc10
    I've just got a subwoofer cable, this should work for the centre channel shouldnt it?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    Yes should be OK.
    As another 1070 owner I would be grateful if you could let me/us know what it sounds like connected up to the Rotel..
    Ian
