Phono cables?
Discussion in 'Cables & Switches' started by Cheng, Jan 5, 2003.
  1. Cheng
    Cheng
    Dec 19, 2002
    374
    +6
    Are normal phono cables (the yellow,white + red plugged cables) analogue or digital?
    I always thought they were analogue - I am very puzzled as my Tosh. 220e requires a digital coaxial cable to be connected in order for it to output DD 5.1, however I connected a yellow phono cable (a free one) and it outputs 5.1 fine?
    Thanks.
  2. Alsproject
    Alsproject
    Nov 12, 2002
    163
    +7
    From my understanding (and correct me if I'm wrong) is that the yellow cable you are using is normally used to carry the composite video signal to the TV. Having said that, the lead is a 75 ohm one so will work with the digital connection as the digital leads are also 75 ohms.
    You may be better off to upgrade the lead to something around the £20 mark as you will hear the improvement (depending on the kit you are using).
    I managed to get a Ecosse "The Producer" cable from www.hifibitz.co.uk for £18.99 and could tell the difference from that and my old QED P75.
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    Surely a coax is a coax...... they will work for digital or analogue, the constriction is the same. Its only that a digital coax prefers additional things, like the terminations.
    ad
