Phoneline for multiroom??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by andloumeg, Jan 15, 2005.
  1. andloumeg
    andloumeg
    Jun 22, 2004
    55
    Having Sky+ installed tomorrow with my existing box moved to the bedroom.
    Does my old box still have to have the phone line connected, or is it just the new Sky+ box (as I would have to run a HUGE extension to get from my socket to the box upsatirs!)
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Depends on how long you've had the old box. It has to stay connected for 12 months.
  3. dsk19s
    dsk19s
    both have to be at all times otherwise u get letters telling u to connect them then you start paying full wack for the 2
  4. pikachu
    pikachu
    ive never had mine conected since i had sky installed, sky 7month, sky plus two month & never had any phone calls or letters yet.
  5. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    If you are having the £10 multiroom subscription the yes BOTH boxes must be connected to the same phone line for the duration of the subscription, it's a security measure and is policed and enforced by SKY.
    If you are going to use the existing digibox (moved to bedroom) as a FTA receiver or with a £20 FTV card it doesn't have to be connected to a phone line. The new SKY+ should be connected (you have agreed as such in the contract) but it is very very lightly enforced.
  6. andloumeg
    andloumeg
    Jun 22, 2004
    55
    I have had yhe old box for over 3 years....would I still need to connect the phoneline??
  7. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    If you are getting multiroom, it doesn't matter how long you've had the boc, BOTH of them have to be connected to the same phoneline.
    I left my Sky+ unplugged for about 2 months and got a letter from Sky.
    John
  8. WRX.CO.UK
    WRX.CO.UK
    Hi, 2 questions to ask, sorry if they have been answered elsewhere!
    1. How do sky benefit from the phone line - is it a marketing thing, knowing which adverts you watch or something?
    2. When installing how do they link the 2 sky digiboxes together where cabling is very difficult. Is it better to diy with your own equipment?
    OK I know the answer to the second one already, UHF connection already inplace for TV and second LBN cable from dish to second digibox.
    Keeping both boxes in living room and using TVlink to control them.
    Lee.
  9. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    When you get multi room, you are effectively getting a second subscription for £10 - far less than the cost of the first subscription. The phone line connection makes sure that both boxes are in the same location otherwise you could, for example, give the second box and card to a family member and they would then get Sky for £10 a month.
    The phone connection is also used when you order box office events.
    John
  10. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    My m8s a sky installer and he has a square 9v battery connected to a phone lead which he plugs into the sky box. The box believes theres a phone line so works normally, including pay for view services.
  11. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    ..... until the Sky card is full, or the subscription price limit is exceeded, whereupon the box won't accept any more PPV. Sky know which boxes have "phoned home", and if they are suspicious they can suspend the account. If your mate is buying PPV stuff with no intention of paying, that's theft, and he could be prosecuted for it. I wouldn't advise anyone else trying this, because getting another job is hard if you have a criminal record.
    The 9V battery trick is well known to Sky.
  12. Crivens
    Crivens
    I just got a letter from them. Basically the phone line in my multiroom is not the same as the main box. Turns out that the telephone line in that room (lodgers room) is actually an NTL one and not my BT one. Haven't got round to answering them yet, but what do people reckon? I mean the engineer fitted it all then said everything was fine. He even showed me how he had connected to the phone line (which didn't have a phone or anything in it BTW) and gone under the carpet. So it's all ok then? Yep he said. So why should I give a monkeys if it turns out it's in the wrong phone line. Didn't even remember I had a socket there in the first place. And stuff if I'm getting a BT connection in the room (which I don't need) for a sky box that no-one uses the phone line for (only use the main box for interactive type efforts), especially when the Sky engineer said everything was fine. I mean what would have happened if I didn't have a phone line in there? I assumed he would fit one. ie. make it all work. If not then what are they saying, you cannot have multiroom in a non-BT room? Erm.... He's an engineer. Whatever it takes to make it all work thanks. Whatever that may mean.
    So what do you lot reckon to that one?
  13. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Well, technically, you are in breach of the Multiroom terms and conditions so I guess that, ultimately, Sky could charge you full whack for the second card rather than the £10 they are currently charging.
    John
  14. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Basically read the T&C's of any contract/service you sign up for and don't rely on a contracted worker to know bugger all about the small print of a service even if he is fitting the hardware.
    Simply put you can have multiroom as long as BOTH boxes are connected to the NTL line or the BT line so that when connected to SKY they confirm they are in the same location.
    It may be worth contacting SKY directly and informing them of the two phone providors in your home as long as both are in your name, there might be some flexibility if that is the case but then again maybe not.
  15. dsk19s
    dsk19s
    ur right jon 6 months he'll be back saying that eng put it on wrong line and complaining about the extra subs
  16. Crivens
    Crivens
    Totally pathetic service then basically. Christ, and I thought NTL were bad. Back saying the engineer put it on the wrong line? Well yeah. I normally laugh at non-techy people (my job is a computer programmer) but c'mon. Hardly top tech we're talking here. "Sky I want Sky+ and MultiRoom, and I will pay you seriously high prices because lets face it there is no competition really", "Ok we will install it for you". You pay your money and couldn't give a monkeys about the little things. I mean grief if I knew that sort of mistake would be made I would install the thing myself.
    Then again, I don't know their answer yet. Could be perfectly reasonable.
    Out of interest, I thought Sky insisted on a BT line originally (they did when I got mine in 2000). I know that wasn't stuck to as my friend plugged his NTL line in, then changed the main phone numbers to go via the NTL cheapy phone number. Sky never chased up.
  17. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Did you inform the installer that the two phone points were actually for two seperate phone services?
    I suspect it's quite rate for a single home to have two landline suppliers and it's quite understandable for a third party to assume that they are either both BT or both NTL and by connecting to them he was making sure you were meeting the terms.
    I seem to recall some issues in the early days with NTL lines but I don't think there has been any issues with them for years, certainly there are no problems with new installations if you only have a NTL or other telco sourced landline.
