Phone with MP3 rings and outlook sync
Discussion in 'Mobile Phones Forum' started by GazH, Jan 13, 2005.
  1. GazH
    GazH
    Apr 17, 2004
    445
    On the corner of Wabash and Lake
    +75
    Hi all,
    I will be upgrading my phone in the next couple of months and was wondering what choices I have (or will have in the next couple of months) of phones with the following:
    - MP3 Ringtones
    - Able to sync with outlook (as I have my contacts on there at the moment).
    I currently have an SPV E200, so I suppose the obvious choice would be another smartphone (c500, mpx 220?), but am interested in what else is (will be) available (non-smartphone).
    I have previously owned an XDA and found it too big so they will also be out....
    Gaz
  2. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    I posted up a question similar to yours on a different forum. I was trying to find a bit of kit that was first and foremost a phone, with PDA bits added on, in a phone-sized package. After getting royally fed up with waiting for the MPX220 to come out, I ended up looking at the XDA, but the size bothered me (as I would still like to look relatively cool when using it as a phone! :) ).
    I believe that many phones out there will sync with outlook, but I got so fed up with trying to get sensible information out of the highstreet store staff that I decided to be 100% sure I had to get something that ran Windows Mobile and Pocket Outlook - no messing around.
    Anyway, to cut a long story short I have literally just (and I mean it hasn't even arrived yet) ordered an I-mate JAM from www.phones2Udirect.co.uk
    I know its still a smartphone, but it's well worth a look in my opinion as it has most of the power of an XDA in a small size (108x58x18mm).
  3. GazH
    GazH
    Apr 17, 2004
    445
    +75
    Now thats a bit funky....
    Its about the same size as my current phone as well...
    Definately consider that one.
    Cheers Darren
    Gaz
  4. GazH
    GazH
    Apr 17, 2004
    445
    +75
    Added Samsung D500 to the list....
    Any more ???
    Gaz
  5. chris4817
    chris4817
    You would notice a huge difference between your current phone and the C500. I have just got it and it is the best phone I have ever had, and small too.
  6. GazH
    GazH
    Apr 17, 2004
    445
    +75
    Cheers Chris,
    I do like the C500, and the fact it is smaller than my E200 is good as well.
    I do also like the fact I can watch movies etc on my phone (and also the C500), but I am also interested in what else is out there.
    TBH I like the V3 as well, but the fact it doesn't sync with outlook makes it a no-no.
    Thanks again Chris
    Gaz
  7. EnigmaCode
    EnigmaCode
    Dec 16, 2004
    265
    +21
    where did you get that (wrong) information from?
    the v3 DOES sync with outlook.
  8. GazH
    GazH
    Apr 17, 2004
    445
    +75
    I read through the thread in this forum on the V3 and I couldn't find anything about it synching with outlook.....
    I stand corrected.....V3 added to the list....oh, and I love the look of this phone :smashin:
    Cheers enigmaCode
    Gaz
