Phone Sockets Broadband Issue
Discussion in 'ISPs & The Internet' started by Dannny, Feb 18, 2013.
  1. Dannny
    Dannny
    Apr 24, 2010
    30
    11
    Huddersfield
    Not sure if this is the right place to post this but hopefully someone can help.
    I'm currently with Sky broadband, my speeds are horrific, I get download speeds of 150-200kbps which is not ideal as I'm an avid PC gamer and downloading big games through Steam is something of a nightmare!
    I've been using a socket like this which is on the windowsill behind my PC;
    [​IMG]
    it doesn't have a test socket and it has a dead moth inside so I'm pretty sure this is old fashioned wiring (at least to me - I'm only 24 :p).
    However after swapping some plugs around behind my PC to give my NAS drive I noticed one that looked like this behind my sofa;
    [​IMG]
    Mod Edit: don't hotlink to images without the hosting sites permission, images re-hosted
    obviously I've had them apart to discover this but the weird thing is the one above (the more "modern" looking one?) is not wired in, it has 2 blue and white wires wired in to it but the rest of the coloured wires are just wrapped around the main cable coming in from outside?
    My question is can anyone shed some light on what is going on with this? Also if I wire in the socket that is currently out of action could it possibly make my internet faster? I've been contemplating changing ISPs but if it's a case of a quick wiring job I'd rather do this!
    Thanks in advance :thumbsup:
  2. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Oxymoron? Please explain?
    That is the Master socket. Connect your modem there, or remove the orange/white wire from the socket you modem is currently connected to.
  3. Dannny
    Dannny
    Apr 24, 2010
    30
    11
    Huddersfield
    Yeah sorry that was a simple moment, the modern looking one is only wired in 2 places and its not to the terminals on the removable front panel and it doesn't work at all. I read if the other one has the ring capacitor then that is the master socket, is it possible to have 2? It says Cabletel on it and theirs a box next to it for a TV aerial with the same name on if that makes any difference.
  4. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Which says it is not a BT socket connection. You obviously have an old house with an old cable connection, but with an, unused, modern BT connection. Who is your telephone supplier?
  5. Dannny
    Dannny
    Apr 24, 2010
    30
    11
    Huddersfield
    It is a really old rental house, my phone is through Sky also.
  6. biagio1
    biagio1
    Feb 22, 2009
    64
    The master socket (if there is one) is normally the one closest to the front door. It might have the words BT or Open Reach or T on the front and if so will have couple of screws which can be removed so face plate can be taken off and then inside there's another socket which is the "test" socket. Normally if there is any broadband problem you will need to plug your equipment in here.
    Pete:)
  7. Dannny
    Dannny
    Apr 24, 2010
    30
    11
    Huddersfield
    The first one I posted is the one closest to the front door and that is the only one with BT written on it, however as you can see on the picture it doesn't have a face plate that can be removed and it doesn't have a test socket. Theirs a small box next to it with BT on it and 2 screws could that be the test socket?
  8. Dannny
    Dannny
    Apr 24, 2010
    30
    11
    Huddersfield
    These are the 2 ports I have that I currently connect to my internet through. I think the dead moth might increase my download speed.
    [​IMG]
    [​IMG]
    As I said the other port is the same as the 2nd one from my original post, it has a test socket etc and looks like it was fitted a lot more recently but it is not wired in aside from 2 blue/white wires. The actual ports for me to plug into aren't wired in at all.
  9. kokolino23
    kokolino23
    Oct 18, 2009
    1,076
    Cardiff
    +48
    That's a lot of rubbish inside!!!
    The second picture presents a 78a and this is used to link 2 cables.
    However, from what I can see in the first picture, the socket doesn't look anywhere near good either ?!
    It's easy to replace both of them but you need the right tools.
  10. deathtrap3000
    deathtrap3000
    Oct 17, 2008
    1,441
    63
    London
    +152
    Second image is an RF2 filter. These are bad for broadband and needs to be replaced or removed.
  11. Dannny
    Dannny
    Apr 24, 2010
    30
    11
    Huddersfield
    can I just bypass it into the actual socket I plug my line into? Or is it not that simple?
  12. deathtrap3000
    deathtrap3000
    Oct 17, 2008
    1,441
    63
    London
    +152
