Phone recommendation please
Discussion in 'Mobile Phones Forum' started by Nick55, Dec 28, 2004.
  1. Nick55
    Nick55
    I currently have a Nokia 6310i which I would like to update. Previous phones were Sony Eriksson T68i (which I hated) & Nokia 6110 which was great. I bought the 6310i because I got irritated with the stupid delay when ending a call on the T68i. Bluetooth doesn't seem to work too well on my 6310i, even though I have updated the firmware. I use a BT headset when in the car.
    I'd like a phone that I can receive email & possibly MSN Messenger would be useful for me. I like the look of the Moto V3, but I'm not sure how good the phonebook is. The V3 appears to have some type of messenger facility. I like on my 6310i how I can search the phonebook & make a call with only about 3 clicks. I also like the look of the Moto Smartphone MPX200, but it doesn't seem to have Bluetooth. The Smartphone idea looks good to me as the Outlook sync would be useful & it also has Messenger, But no Bluetooth is crazy!
    Coverage in my local area means I can only consider Vodafone & T-Mobile. GPRS is patchy but ok.
  2. EnigmaCode
    EnigmaCode
    Dec 16, 2004
    265
    +21
    the phonebook is one of the best there is.......and yes, you can group multiple numbers/email under one contact.
    unlike the others, yiou can store all your numbers/email for each and every contact on the sim if you choose. you can also have unlimited numbers/email for each contact. has group texts/email.
    it has chat and IM.
    voice record ;)
    the bluetooth on the v3 is one of the very best. it is 100m. also, if you break the connection at somepoint, the v3 stores an instance of that pairing and will try to reconnect. theres no need to re-search for the device again.
    hope this helps
  3. Nick55
    Nick55
    Thanks for your reply.
    Can you tell me more about the IM facility? Would it work with pc contacts who use MS Windows Messenger?
  4. ramseyculdesac
    ramseyculdesac
    ARE YOU WANTING TO KEEP WITH NOKIA, COZ THEY ARE BRINGING OUT A SMART NEW PDA STYLE PHONE SOON.
  5. yaserk99
    yaserk99
    Dec 30, 2004
    9
    West Yorkshire
    If i were you mate i would personally go for the V3 which you have been explained to about or i would go for the new Nokia 7710 or the Motorola MPX220. This is the new updated version of the MPX200, it has added features such as a 1.3 MP camera with flash, bluetooth, and updated windows mobile operating system, and being a motorola - like a nokia- you can put the email address, phone number etc under one contact. hope this helps ya mate. cheers.
  6. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Nick, consider the T-Mobile SDA, same hardware as the Orange SPV C500 but with a different look. It has all the features you're looking for.
  7. Tomfoolery
    Tomfoolery
    May 16, 2003
    148
    UK
    +10
    The SPV c500 does have bluetooth, a decent battery life (unlike earlier SPVs) and the things you've pointed out like msn messenger.
  8. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Which is what I use, except the OP is restricted to Vodafone or T-Mobile, hence my reply :)
  9. EnigmaCode
    EnigmaCode
    Dec 16, 2004
    265
    +21
    don't know - never used it :). its there just in case i want to though.
  10. Tomfoolery
    Tomfoolery
    May 16, 2003
    148
    UK
    +10
    Whoops, missed that sorry. Yes, I heard about the T-Mobile SDA, sounds just as good.
  11. ramseyculdesac
    ramseyculdesac
    sounds like the 7710 has alot of the same features as the motorola. Anything which distinguises one from another?
