Phone (RCA) leangth. Will 14 Metres loose quality from Amp to Sub?
Discussion in 'Cables & Switches' started by iMan, Dec 11, 2003.
  1. iMan
    iMan
    Mar 30, 2003
    34
    Just in the middle of installing an Home Cinema Projector system. My A-V Amp is 4 metres away from the Bass Subwoofer, for me to run the phono lead from the Sub to the Amp routing it properly around the scirting boards will come to 14 metres.
    The man at the shop told me that if I used a Phono cable that long it will loose amperage/power/quality? something like that anyway.
    Is it okay to use a Phono lead that long? has onyone experienced problems with such a long Phono lead from the Amp to their Sub?
  2. Stu M
    Stu M
    Oct 28, 2002
    13
    3
    London
    If its an active sub which I assume it should be fine but it might get some noise pickup fro fridges and washing machine motors. If it works then don't worry all will be fine :)
    Regards
    stuart
  3. bobbypunk
    bobbypunk
    just buy a slightly better shielded lead and make sure it's a dedicated sub lead and you'll do the best you can.
  4. oatmeal
    oatmeal
    Oct 12, 2002
    1,652
    38
    Home of the worst postal system in the world.
    +15
    I've just put down an 8 metre lead and it works fine with my active sub, though I should point out that there are no other appliances anywhere near that part of the house other than the AV set-up so perhaps I can't be too sure about how you'd fair with washing machines etc!
