Phone monitoring app
Discussion in 'Mobile Phones Forum' started by HistoryGirl, Feb 15, 2014.
Tags:
  1. HistoryGirl
    HistoryGirl
    Jan 19, 2010
    75
    11
    +5
    I'd like some recommendations for an Android app that I can use to monitor my phone for example battery consumption, phone temperature etc. I've used go power briefly in past but any others? I'm running Kitkat if that makes a difference.
  2. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    I like Battery HD Pro. Got it free from Amazon. There is a free version Battery HD.
    Has a good looking widget and very easy to use.
  3. RobM
    RobM
    Dec 29, 2006
    13,227
    +2,168
    As an alternative option, have a look at Zooper. It's a customisable widget creating App that lets you create your own widgets with all sorts of information in them, including the things you're looking for and other similar parameters. You could have one that shows battery charging / discharging rate, battery temp, phone temp, IP addresses, uptime, you name it... it can be as simple (plain text, no background) or as complex (icons, graphics etc) as you wish.
  4. HistoryGirl
    HistoryGirl
    Jan 19, 2010
    75
    11
    +5
    Ok thanks I'll have a look at both
