matty_wills
Hi there I actualy joined to ask this question I did a quick search but couldn't realy find anything that helped,
Heres the situation I had sky+ hd installed in the living room a few months ago and got a normal sky box in my bed room with multi-room
then i wanted to move the tele from the corner to the centre of the wall no more than 2/3 feet becuase the tele was too big for the corner anyway I had to extend the cables from the dish and re-threaded the phone line through the wall, but then found out the phone line from upstairs wasn't long enough to reach the sky+ hd so it's no not connected to the phone line and just got a letter saying if I don't connect it I will have to pay double which is fine but I'm not sure what type of cable is used for the phone line on sky boxes?
Also I've got the Sky HD Box connected to the phone line but when I try to use a service that needs it, it says it can't connect is this becuase the multi-room box is not connected to the phone line or when I moved it have I re-connected it wrong?
Thanks for any help in advanced
Matty
Matty
