phone line & Sky+
Discussion in 'Sky Digital TV Forum' started by Maximus1633, Dec 3, 2004.
  1. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Do you still need a BT line for sky+ do you need it for the install and then pluged in all the time. I have a standard pace sky box at the moment and do not have it pluged in to a bt line can you use NTL phone line? im thinkin of getting sky+ im already a customer.
    thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    NTL phone line will work just fine.
    The phone connection is only required for the first 12 months and then only if the system is supplied and fitted by SKY.
  3. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Ok thanks for that so you don't need it for the sky+ ok have to see if i can get it for £99 now.
  4. LDJ
    LDJ
    Jun 18, 2003
    605
    +27
    i haven't had the phone line connected since the day i had sky and sky+ installed respectively.
  5. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Thanks again i will give them a ring now.
