Quantcast
phone call over LAN (no internet)
leecavturbo
like skype but only using internal network lan. no internet.
ideally with an app for android phone
i can skype to skype on android over wifi but internet must be connected.
possible?
even with voip phones?
gary99129
It's technically possible and not exactly revolutionary, Netmeeting on Windows 9x could do it.
The best way is to use a software PBX (a PBX is a telephone switchboard) e.g. Asterix but that's overkill.
Try looking for H323 software for Android and whatever other devices you are using and take it from there.
Hopefully somebody will be along to give you more detailed advice.
