Phlips 42pf9966
Discussion in 'Plasma TVs Forum' started by pino71, Jan 8, 2005.
  1. pino71
    pino71
    Jan 8, 2005
    2
    Hi to all,
    i've the plasma philips 42pf9966.
    Anyone can tell me if this plasma has the PiP function?
    I have not found this feature in menu!!!
  2. Stonedragon
    Stonedragon
    Jul 9, 2004
    158
    I've got the above model and it dosen't.
  3. lemke
    lemke
    Nope, only one tuner
    and not even with other resources.
    Lem
  4. mangawhaiheads
    mangawhaiheads
    I have just brought this model plasma and it definitely has PiP functionality. In fact you can select between 1 2 3 4 or 6 Pip's (i.e. you can split the screen into 6 different screens).
  5. lemke
    lemke
    hmmm, interesting
    How did you set it up?
    Lem
  6. mangawhaiheads
    mangawhaiheads
    There is a "PIP Format" option in the menu under Setup - General -
    This allows you to specify how many PIP screens you want displayed. You then simply push the PIP button on the remote to activate
