phishing filter
Discussion in 'Computer Software & Operating Systems' started by lisa burrell, Jan 2, 2007.
  1. lisa burrell
    lisa burrell
    Is it my set up or what but ever since this new i/e7 With the Phishing filter enabled my computer very slow. Do you you all turn the filter of?.
  2. t1m103
    t1m103
    Jun 29, 2005
    1,856
    essex
    +191
    yes ive disabled it in the advanced setting in internet options,it was causing my cpu to sit at around 45-50% usage,plus it did seems to speed up things after.
  3. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    If you think your an experience enough user, then go ahead and disable it. I've have it set to off, so that I can check dodgy sites manually.
  4. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    I've been using an Anti-Phising Toolbar on Firefox for the last 9 months with no noticeable speed difference, if you fancy swapping browsers.
