Phillips TV and Maratnz RC2000
Discussion in 'Home Cinema Control & Remote Controls' started by Sven Tribbe, Jul 6, 2001.
  1. Sven Tribbe
    Sven Tribbe
    I own a Philips 34 inch flatscreen TV (non-widescreen as we dont get any widescreen in NZ other than DVD) and a Marantz RC2000 mk II. The remote has been able to learn anything I have thrown a it including the hard to learn sony 2 way IR remotes sound field codes. However it doesnt deal with the Philips codes. It will learn them but when retransmitted the TV seems to get confused - it will work first time but not second time. Have to wait 10 or so seconds to try again - seems as if the TV is waiting for the rest of the code or something. Seems strange especially given the remote actually comes with Marantz/Philips codes built in. Any help? :confused:
  2. Fartpants
    Fartpants
    have you looked at www.remotecentral.com, there is a very good chance you can download the codes from there.
