Phillips remote sensor didnt work
Discussion in 'General TV Discussions Forum' started by FreeBeeb, Aug 25, 2006.
  1. FreeBeeb
    FreeBeeb
    Hi i have a Phillips tv that type[​IMG] of it and the remote scensor dont work help me :(:lease:
  2. mctech
    mctech
    Jan 3, 2006
    121
    SCOTLAND
    +4
    Need a model or chassis number.Looks like it could be a l04E chassis but cant be sure........
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    Bradford, West Yorkshire.
    +325
    Lots of Philips sets look like that. :suicide:
    A model number would be useful. :)
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  5. JayCee
    JayCee
    Jan 20, 2004
    23,486
    Lanarkshire
    +2,532
    It is pointless including a picture of the set as most of the Philips models look alike.
    You need to post the model no taken from the rear label on the set.
    It is unlikely to be the IR sensor.
  6. FreeBeeb
    FreeBeeb
    Do they sell IR sensor at maplins?
    And i got taught the tv is Pixel+.
  7. JayCee
    JayCee
    Jan 20, 2004
    23,486
    Lanarkshire
    +2,532
    We still need the model no.
    I wouldn't think Maplins sell them.
  8. FreeBeeb
    FreeBeeb
    The number is A140 erm i found it at the back of the tv sticker.
  9. JayCee
    JayCee
    Jan 20, 2004
    23,486
    Lanarkshire
    +2,532
    That isn't the model no.
    The model number consists of...
    2 numbers like 28 or 32
    followed by
    2 letters like PW
    followed by
    4 numbers like 9623...
    So in this example it would be 28PW9623
  10. FreeBeeb
    FreeBeeb
    God that TV is mounted in the wall! :(
  11. JayCee
    JayCee
    Jan 20, 2004
    23,486
    Lanarkshire
    +2,532
    The model no will be printed on the front of the user manual although for accuracy it's always best taking it from the rear label.
    I have never had to change the remote sensor on a modern Philips...if you see "A10E" printed on the rear label that is the chassis type fitted and one of the most common symptoms of a faulty "Painter" IC is remote lockup after 15-30mins...if it is you are looking at a big repair bill.
  12. sheldonstv
    sheldonstv
    We repair a lot of A10s and find them pretty straight forward.....a common fault is loss of the supply for the ir sensor due to poor soldering-you need to order the correct type of ir sensor for your set as space is limited as to where it is fitted and you cant just replace it with any old type as it may not work-the painter ic does have its faults but sometimes resoldering cures it....if not as long as you have COMPAIRE reprogramming is easy.
    regards mike
  13. FreeBeeb
    FreeBeeb
    32pw6515/05 but here is the code :)
  14. FreeBeeb
    FreeBeeb
    The badest thing is i accidently set the childlock on :( at the top buttons
    some days the sensor works for like 10 seconds :mad:
  15. FreeBeeb
    FreeBeeb
    hello got the model number will you help me :(
  16. nig28
    nig28
    Are you are saying your remote control does not work?
    I assume you have tried batteries, if so are wanting to know were to buy a new remote control, this is different from buying a sensor.
    Nigel
  17. FreeBeeb
    FreeBeeb
    No not the remote control its the tv sensor that not works, it works certain days for 10 seconds
    Plus someone accidently put the childlock on by the top buttons :mad:
  18. nig28
    nig28
    How do you know it is the sensor? Replacing a sensor is not an easy task, unless you have been inside a TV before.
    Very few repairs on a TV can be done by a DIYer.
    Nigel
  19. FreeBeeb
    FreeBeeb
    Yes we put it out and put it back in and it works for a while :mad::mad::mad::mad::mad:
  20. FreeBeeb
    FreeBeeb
  21. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    +325
    Do a search for 'painter IC'.
