Phillips on digital tuning problem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Bush5, Oct 9, 2004.
  1. Bush5
    Bush5
    Hi. I have an old Phillips On Digital box that is tune into the old stations. I can recieve BBC1/2, ITV1/2, 4 and 5, but not the other freeview chanels. If I try 'auto update' it comes back with an error message. If I try searching for new chanels it stops halfway and will not save.
    How can I update this box and get it to work properly? The signal appears strong with clear pictures on all the chanels I am recieving at the moment.
    Any suggestions please?
  2. peggle
    peggle
    Aug 29, 2004
    156
    +23
    Philips no longer support this box. No updated S/W is available, hence the message.
    Find the Mux channel No's here :-http://www.bbc.co.uk/reception/tv_transmitters/tv_digit_full.shtml
    Then check the signal strength for each Mux by MENU,7,1.
    Give the channel search time at least 15 minutes. If still no go try ADD CHANNELS MENU,5,3.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,441
    Rainham Essex
    +2,470
    If you still have the old OnDigital/ITVDigital card in the cam slot then remove it as this is no longer required and has caused problems for some people when trying to add/update their channels.
    Mark.
