paulrw
Established Member
Anybody used the Samotech sm309?
I want something to make my 2off 5 28w halogen bulb chandeliers smart with hue hub and hue switches.
Do i just cut the 2 wires to the light fitting and then fit these in between?
One for each chandelier?
Will this then give on/off/dim and full functionality with hue switches, sensors etc just like a hue bulb?
Amazon product ASIN B07Z9GCT6NView: https://www.amazon.co.uk/Zigbee-Dimmer-Switch-Compatible-Echo/dp/B07Z9GCT6N/ref=sr_1_1?crid=3NXO425GCLAI8&dchild=1&keywords=samotech%2Bsm309&qid=1607354822&sprefix=samotech%2Bsm309%2Caps%2C159&sr=8-1&th=1
I have hive bulbs and plugs, so hopefully they can join the hive app later on......
— As an Amazon Associate, AVForums earns from qualifying purchases —
