Phillips freeview help
Discussion in 'Freeview & YouView' started by nwgarratt, Oct 21, 2003.
  1. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    I have had freeview since it started through my IDTV. Reception has always been fine.
    I bought a Phillips DTR 1500 to record to my Panasonic DVD recorder.
    The IDTV has a loopthrough, so I plugged the aerial into the IDTV and fed it through to the Phillips.
    I was getting break up on ITV/ITV 2 and Channel 4 chanels on the Phillips. It would only happen every couple of days or so. To sort it out, I would have to move the aerial cable.
    I have now put the aerial striaght into the Phillips and then to the IDTV. I am still getting the breakup.
    If the aerial is ok for the IDTV (which is next to the Phillips), why does the Phillips break up.
  2. Worm
    Worm
    Mar 4, 2003
    246
    +8
    Cant reallly help you but I have the same sort of set up and it happens to me on channel 5 and my IDTV is a phillips. Channel 5 is great on the IDTV but not on the STB, Have tried various aerial set ups/boosters but only a virgin reset on the box works and only till I try to record something off 5 and the breakup starts. I have 023 software and I think the weakest channel 5 signal is being used . The update to 032 supposedly sorted this out ,so am waiting for that.
    Perhaps your problem id the same
    Regards
  3. PhilipVass
    PhilipVass
    IDTV and a Freeview box on the same tv, right? if so then you you could put the Phillips DTR 1500 in a room if you have another VCR and then you can still watch Freeview in the lounge and somewhere else in your house.
    Just an idea :)
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    Both have to be in the same room.
    I just want the break up to stop. The aerial is going straight into the Phillips.
    I wouldn't mind if the IDTV broke up as I will use it to watch a digital channel while recording another. The reception of the digibox is the most important as that will do the recording.
    I try the virgin restore.
    Edit: It still did it after a restore. I took the aerial out and moved the aeria cable a bit and plugged it back in. It is working again (but for how long?).
    Does anyone else know a good box with RGB in on the VCR scart? Just keeping my options open.
  5. Pod Person
    Pod Person
    I use the Phillips DTR 1500 and notice that it reduces* the signal slightly through its loopthrough, (analogue picture is more grainy).
    This might explain the digital break up.
    *Attenuation ? Correct term?
  6. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    I am not getting th break up when using the loopthrough. I did but I am still getting it when the aerial is going straight to the phillips.
    I will put the signal strength meter on the screen, and move the aerial a bit and see if I can improve it.
