Phillips DVDR75
Discussion in 'Blu-ray & DVD Players & Recorders' started by Techno Freak, Jan 16, 2004.
  1. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    Hi all,
    Richer sounds have these units for £219 - multi-region.
    I was not in the market for a recorder just yet but the cheapest outside of Richer Sounds is £399.
    I can't resist at this price.
    I only want it to archive stuff from Sky +
    Before I buy one I wondered if anyone has got one of these or has experience of one?
    Any coments on it would be appreciated.
    Is it better to go with this or a DVD-RAM machine? ( time-slip is not an issue ).
    Thanks.
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Take a look through a few pages of threads and see what the Philips versus DVD- problem ratio is.
    If you want to do editing of any kind a HDD machine is best,but they are around £500,but do allow flexibility of editing that easily matches any PC .If its movies only from Sky+ any recorder will do the job
  3. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    I am not bothered about any editing - I just want a vcr replacement.
    I am worried that the 20 hours sky+ will fill up too quickly so I thought a cheap DVDR75 would do the job of freeing up sky+space a treat.
    Also, it has the i-link which would be ideal for archiving camcorder footage - again, I am not bothered about editing but I would require compatability with plenty of other dvd players for handing out copies of said camcorder footage.
    I am a little worried about the amountof bugs I have seen mentioned on the forum regarding the phillips machines, but thats what warranties are for.
    I think I will go for it as it is so cheap and seems as though it will fit the bill exactly for my needs.
  4. primitive
    primitive
    Aug 22, 2003
    95
    The Philips machine will be an excellent choice for archiving from Sky+. I have the DVDR70 for exactly that purpose and it is fantastic.
  5. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    Well, bought a DVDR75 this morning - wicked.
    I am well pleased with it.
    It is very simple to use, the quality of recordings are excellent.
    I recorded a few things of Sky onto a DVD+RW then popped the disc in my other players - all worked great. I like the simple menu it produces on the disc for selecting recordings.
    I am very happy with my choice, the qaulity is supberb and has all the functions I need. Just have to wait and if any problems arrise with the machine itself over time.
    PC world have a great sale on at the moment. I bought a spindle pack of 25 DVD+RW's for £29.99 !!!!
    I will keep this thread posted with any problems I encounter on the machine.
    Does anyone know if you can copy a recorded clip from the DVD direct onto your pc hard drive?
    Thanks.
  6. SystemBlack
    SystemBlack
    The DVR 75 isn't strictly multi region as I thought that too, it is region 2 or "all" region compatible. I use DVD+RW to master in anything from 1 hr to 6 hr, edit the chapter markers to eliminate ads, make the disc "compatible" and play that from my DVD player and record onto DVD +R. The thing I found the other day was I put a RW in to record Red Planet and when the film had finished, I pressed stop and the machine locked up. I had to unplug it to reset it so I lost the file. That is the only problem I have had in 3 weeks. If it does it again it's going back but I have used VHS SP to VHS LP editing (up to 5 films on a 4hr tape) but was always dissappointed with the quality. Not any more. If a film last 2 hours I can record in M2 mode, if it lasts 2.5 hrs I can record in M2x (or 2.5 hrs) mode so I get the best possible quality on the master. I like the operation a lot and when you burn a DVD+R and finalise it, you even get the Philips menu to choose titles from. get one, you know you want to.
