phillips dvd75
Discussion in 'Blu-ray & DVD Players & Recorders' started by nuggettss, Oct 19, 2004.
  1. nuggettss
    nuggettss
    my friend purchased the 75 a few weeks ago but was unable to download the analogue tv settings
    now uses freeview box to view tv
    in the settings menu the uk pal system line is missing
    will the upgrade cure this or is it a software fault
    thx
    colin
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,675
    Did you the buy the recorder in the UK? If not it probably doesn't have a compatible tuner.
    I should poiny out that you are considerably better off using the Digibox picture than the internal analogue tuner. With the Digibox you can record in full RGB whereas RF always gives very poor PQ.
  3. nuggettss
    nuggettss
    thx for quick reply, he thought it might be european model, bought it from empire direct
    quite cheap at the time 219.00
    was going to return it, but wanted to record the tour de france fortnight
    machine ok otherwise
    cheers
