T
T4R
Firstly I've just registered today, and I hope that with my first post I'm not contravening forum etiquette.
I'm looking to replace an aging Toshiba 4:3 which has given many years of almost faultless service with a widescreen, as with DVDs the picture is cut down somewhat.
I'd almost decided on a Phillips 28PW9618 as from what I've seen of PixelPlus the quality, fast moving ball games aside, is astonishingly good.
I'm more than a little concerned however about reviews and posts I've read of problems with the image, black bars or smudging, with little or no help from the manufacturer or dealer. Am I right to be concerned or are these a few isolated "one-offs" ?
If the consensus is that Phillips should only be purchased with a degree of caution, are there any recommendations for another 100hz TV with reasonable connectivity.
Please excuse my ignorance here - I have another question. The Phillips 9618 has 4 Scarts, two of which are RGB, which I presume I should poke into my Sky+ box and cheap Sony DVD player. What would the other two be used for, and what signaling do they utilise ? I also have a Sony VCR and a PS2.
Many thanks in advance and again, I hope this isn't gong to upset anyone.
Regards
Concerned of Cobham
Regards
Concerned of Cobham
