phillips 963 sa/need help urgent..thnx
Discussion in 'Blu-ray & DVD Players & Recorders' started by zoro, Feb 10, 2003.
  1. zoro
    zoro
    Jan 23, 2003
    326
    +7
    Is it compatable with DVD-R, DVD-RW?
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    dvdrhelp entries suggest it plays DVD-R (not -RW) & that it plays both +R & RW.
    Don't have one myself that is just from the above website.
  3. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Ive tried DVD-R and DVD+RW on this player and it refuses to accept the DVD and ejects it after about 4 seconds.
    Anyone had any success with DVD-R on theirs?
    Off topis but I hate the contrast setting menu. Zero contrast setting is too bright on darks scenes. If you put it on contrast plaus 1 igets darker. If you put it on contrast minus one. It also gets darker. The scale system is faulty!! Can anyone else confirm this on theirs?
    Deks
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Philip's being a champion of the DVD+R format, that would be the logical disc to try.
  5. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Yep i'm looking down those lines at the moment. Looking at +RW at the moment. I will post results as they become available
    Deks
  6. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Quick updtae to cofirm 963SA IS compatible with DVD+RW :)
    About to try -RW
    Stay tuned
    Deks
    ps i'm so bored this afternoon I think I need to find some paint to watch drying!
  7. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Just an update to say the 963sa is NOT compatible with DVD-RW.
    Just need to check DVD-R. I hope it is compatible as -R are still cheaper than +R.
    As a side note I tried the -RW DVD in my old Sony 300 DVD player and it played no problems.
    Deks
  8. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    I can now confirm the following
    963SA compatible with following
    DVD+RW
    DVD-R
    Definately NOT compatible with
    DVD-RW
    Unfortunatley I have no +R discs to check with it
    Deks
