Phillips 42PFP5332D - green light and flashing red light
kinetic3
I posted this same post in the below thread - and was told to start my own post/thread. Thanks in advance
Btw I have not tried using a hair dryer on the board - but tonight I will - and will update post. Also I will post pictures later to help out.
http://www.avforums.com/forums/plasma-televisions/400763-philips-plasma-blink-18.html
hello all - I have a Phillips 42PFP5332D/37 and it gives the single green light than 6 flashing red lights when the power button is pressed. If the power button is not pressed the six red lights will just flash pause and repeat.
I opened the back of the Plasma and was surprised to find that Samsung made the boards. Anyway - can anyone offer some help? I checked the caps and they all seem flush and not broken/popped. I can not seem to find any of the numbered capacitors that other posters have posted to look for.
Heck I can not even find anyone with a similar model number to my plasma...
If it helps I can post pictures of the boards/back of the plasma/anything... and the model numbers from inside the plasma.
Thanks in advice for any and all help
kinetic3
hair dryer did not work - post pictures later - still solid green light and 6 flashing red lights.
Any help on this - could it be the power board? Or capacitors?
arkinsee
Hello kinetic3 & mvrban
does it smell 'fishy' ?
Whats this ringed on pcb ?
Good clear pictures what camera you using ?
sorry :oops: posted to wrong person this was to mvrban
rayferry
I had a look for known faults on this model but I'm afraid there are none listed, judging by your photo there is nothing obviously wrong with the capacitors in the power supply but you would need an ECR meter to check. It looks as though you will have to write it off or get an estimate for repair. A service manual may tell you what the sequence of LED's fault code is but it does point to a power supply problem.
kinetic3
the picture arkinsee posted is not my board - its from a user with a 50 vs the 42 I currently own.
Photos will be posted tonight - **crosses fingers**
Would it be better to get a new power board or buy a "broken plasma for parts" tv from ebay?
Just to make sure - the power board is the board in the middle of the tv?
Also would calling Phillips do any good?
arkinsee
hello kinetic3
sorry my bad :rolleyes::oops:
kinetic3
images attached - tell me what you think -
rayferry
Nothing obviously wrong in the photos you supplied, the capacitor tops all look pretty flat but as I said without testing them with an ECR meter you can't be 100% sure. Can you look at the other PCB's in particular bulging capacitor tops they should be flat and not bulging it may give a clue as to where the fault lies.
You may be able to source a replacement power supply board from ebay.
Contacting Philips, they will probably refer you to dealer and a replacement power supply if aviailable would cost £200-£300.
kinetic3
Whats an ECR meter? where can I find one?
I can supply photos of the capicitors up close.... will try and do this tonight
There are some boards on ebay - my concern is, if I buy a new board - how long before that one goes....??
Thank you for your help really appreciate it!!!
kinetic3
OK I took more photos of the tv board capacitors....
One thing a poster in the "tv on the blink" thread posted something about removing the the connectors to the main power board or the Y board... Anyway I am not sure if this matters or proves this is a power board issue. But when I removed one of the connectors (specifically two - i have a pic of them) to the board - no more flashing lights --- the tv wont turn on but hey I think I am getting somewhere...
the first photo in the first row shows three connectors two white and one grey - the white ones if disconnected make the flashing lights go away - but specifically these two ...I can remove any other connector and the flashing green and then 6 red lights will still occur...
Thanks again for the help
kinetic3
Just called phillips - just to "check" about warranty and service.
Phillips does have a one year manufacturer's warranty and if anything goes wrong they will replace/fix the TV with no cost to me (seems decent). They would send out a tech to my place and fix the TV and then leave...
**now for the extremely funny part**
However, if I want to get a warranty (and was within the 1 year purchase date) I could purchase a 3 year warranty from Phillips for the amazingly low price of $600 usd. No warranty outside the 1 year manufacturer warranty.
reference numbers
Contact Phillips basic tech support USA - 1-888-744-5477
Contact Phillips warranty service USA 1-866-309-9913
The fun continues
kinetic3
I am not sure about the warranty - I got the TV from a friend - I know he gave up on the TV about 6 months ago. And I just acquired it 2 weeks ago.
What I am sure of is the boards inside the TV have a 2007 date... I could get lucky - I will try calling Phillips with the serial number later and seeing if its within the warranty period.
If its not within the warranty period - I would like to try and fix it or get something from eBay. Which-ever would be easiest .... and of course cheapest.
kinetic3
bump
Any help? Anything I can try? Should I try and locate an ESR meter? Buy new boards? How can I tell which board is bad?
perceptionist87
bump
Well, you really are systematically approaching the problem.
Did I get this right?
1) You purchase a broken TV and you are to repair the thing
2) Then first thing is to produce a screwdriver and open up the Plasma TV's case by which you redeem your entire guarantee in the first place, regardless of buying date.
3) And then you are calling Philips and seriously ask them whether or not you have guarantee on the TV which is probably spread all over in its different fragments by now?
:rtfm:
You might not believe this, but accidently I had exactly the same TV you have. Oh how I would like to help you, but If you would have posted BEFORE you open up your whole thing, it would have been one hell of a lot easier.
Sorry, I am no technician.
kinetic3
1) the tv was given to my by a friend - it has not been working for a while - about 6 months +
2) The warranty call to Phillips was just to see if they would fix it vs me trying to replace a board which is bad. Going from the "philips tv on the blink" thread I figured people could help me solve my problem "systematically" by eliminating certain things that could easily determine what is wrong with the Plasma
3) The pictures I posted show the TV still in one piece - which it is
A very generous poster on here is sending me the service manual so I can figure out how to fix this.
I will keep this thread up to date with any technical updates - for future posters who can learn from my experience.
Thanks for your help!!
kinetic
zchornyak
Kinetic, did you ever get that service manual? I have the same TV with the same problem and am going to attempt to repair it. If you have that manual and feel like sending it along it would be much appreciated. I'll let you know if I have any luck with the repair.
Have you fixed yours yet?
kinetic3
I did get the service manual - While I am a technical guy - I am not an electrical **technical** guy. Some of the stuff reads in Chinese to me.
I even had a guy come out and look at it - he said it was the PCB (thats the main one in the center of the TV). He started to solder the bottom of the board - I asked him to stop before being charged 350 usd. He said Philips TVs are not the best and there can be varying things wrong with them even if two TVs display the same error.
I wish I could tell what was wrong (if its a simple job of a capacitor or if it is a whole new board) - even the remote that was received with the set is not functional. I was going to buy a PCB off of ebay this week - I may hold off if you are going to try .
PM me your email addy....
btw please keep this thread going with any updates.... can you post pictures also?
kinetic
ced70
I heard that it was either the SSB or the power board. My TV flips the relay as soon as it is plugged in then I get flashing red lights. All fuses on all boards were okay. I am not sure what else to look at. Can anyone post or email the service manual?
Thanks,
Ced
Latest News
LG rumoured to release 97-inch OLED TV in 2022
  • By Andy Bassett
  • Published
What's new on Blu-ray (UK) for Halloween 2021
  • By Mark Costello
  • Published
AVForums Movies Podcast: 20th October 2021
  • By Phil Hinton
  • Published
PSB announces M4U 8 MKII wireless headphone
  • By Andy Bassett
  • Published
Melco introduces N50-S38 music library
  • By Andy Bassett
  • Published
