fangface666
Established Member
Hi guys, quick question, got a phillips 42pf9946 back in December from Comet at the bargain price of £650 (old model, half price clearance) with which I am well chuffed.
Have read all posts on here about lipsync probs, ie watching Sky on plasma but taking sound from Sky box through Amp.
I have used the engineers menu to adjust the settings, with some degree of success, but today decided to have a jig about with inputs etc, and connected the tv's audio out to the amp, for the first time since purchase, only to discover that there is no output!
I have gone through the instruction book and menu's but cannot find anything relating to this apart from the following
"To connect to a hi-fi system, use an audio connection
cable and connect the L and R AUDIO outputs on the
TV set on the AUDIO IN L and R input on your hi-fi
amplifier."
Extensive HUH
Now its not the leads or the amp as I have tested them using a different source.
After all that waffle, does anyone know if there is a way to enable the audio outputs, or is it a fault with the plasma, And dont say thats probably why it was cheap LOL
amplifier."
Extensive HUH
