Phillips 37PF9965 Plasma problems....
Discussion in 'Plasma TVs' started by FarleyUK, Nov 8, 2004.
  1. FarleyUK
    FarleyUK
    Hi all!
    I recently purchased the above plasma TV, and have a few problems with it...
    Firstly, I have a DVD player connected to it via a Monster SCART cable in interface 1. However, I notice that green seems to seep into the picture a lot. It's not there constantly, but seems to kind of 'pulse' between green and not green. I have tried changing the settings between Pixel Plus, Progressive Scan and Movie Plus, but the problem is still there.
    Secondly, I have a chipped Xbox that I want to use the High Definition on. I was told that this TV supports HD, but later found out that it only supports interlaced HD via the components in the back. I need it to support the other HD (progressive, I believe?) as this is the signal the Xbox outputs. I have a VGA adapter and have been informed that the VGA input will accept a progressive HD signal. However, how do I connect it??!?!?!?!?!
    Thanks all!
    :lease:
  2. FarleyUK
    FarleyUK
    Anybody?
    Please???!?!?!?!?
