Quantcast
Phillips 32pf9976 tv connecting via DVi-i to component dvd problems
andyeggleton
just purchsed a DVi-i to component cable to connect to my dvd player, the only problem is that i am getting a white broken line accross the top of the screen which is very annoying. Spoke to phillips they said it's because the t.v is not HD ready !!!!! any clues ???
fredsie
Not sure but I think what you're seeing is the data line which prompts the format switching to widescreen for European DVDs. If that's it, I don't think you can do anything about it.
