Phillips 32PF9976 - Component to DVI? help!
Discussion in 'LCD & LED LCD TVs' started by NeilTh, Dec 23, 2004.
  1. NeilTh
    NeilTh
    Dec 1, 2004
    I purchased a set of component to VGA leads from Beststuff and they arrived yesterday, and connected them to the 9976 via the VGA>DVI adaptor and the component plugs to my Sony DAVS550 DVD player (component output) and switched over to progressive scan...
    and...
    nothing!
    on DVI input on Tv - blue screen and some text on the sceen saying "format not supported"
    Can anyone offer some suggestions?
    I've read the same thread on the 9986 tv - is this the same firmware issue?
    thanks
    Neil
  2. NeilTh
    NeilTh
    Dec 1, 2004
    nobody got any ideas??
    Neil
  3. axc
    axc
    Dec 4, 2004
    5
    The 32PF9976 only supports component input to DVI if its firmware is > 2.0. So you need to check your firmware version, which you can do by using the service menu. You access the service menu by typing 654321 (I think) on your remote.
  4. NeilTh
    NeilTh
    Dec 1, 2004
    ok - tried that - it reports SW version as 2.0_07301 - so would assume this is the latest?
    have tested the component output of the sony dvd player on my projector and it works fine, so not the dvd player at fault
    any ideas?
    Neil
  5. patterson
    patterson
    Nov 4, 2004
    Neil
    I have the Sony HX900 and I had the same problem. It took me ages to figure out that all I had to do was to select 'progressive scan,' output for the DVD. There is an option to do this on the remote for the DVD I have and I believe it can also be found in the setup options.
    Your DVD player should hopefully have similiar options.
    Hope this helps.
    P
  6. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Yeah, check that the DVD player is outputting Progressive Scan. This is exactly the same as the 9986 and all I had to do was press the Progressive Scan button on my Denon player and away we went! Selecting ProgScan (as long as you've selected DVI, of course) on the TV doesn't seem to matter, in fact running PixelPlus improves the picture further.
    Jimmy
