Phillips 30PF9946 or LG DI30LZ30
Discussion in 'LCD & LED LCD TVs Forum' started by jimba, Mar 27, 2005.
Tags:
  1. jimba
    jimba
    Looking to buy a 30/32 LCD this week , Like the look of these two. The LG looks like a better spec , but noticed a lot of negative reports on LG's .
    :lease: help
    If any other suggestions my budget is around £900-£1300. Thanks
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    LG have not acheived anything of particular note in the LCD market, despite being in cahoots with Philips who have...
    Lots of TV's within your budget. The Philips you mentioned is OK. Could you stretch to the Philips 32PF9976. Top TV with full HDTV facilities and Philips pedigree. (£1400+ a wee bit). Look out for the Toshiba 32WL48 at less than £1300. Good spec and performance...
    Jimmy
  3. jimba
    jimba
    cheers jimmy, Love the look of the 32pf9976. Will go and look in the shops and prob buy . Again Thanks.
