Philips963saPAL questions from a Newbie
Discussion in 'Blu-ray & DVD Players & Recorders' started by Argento, Jan 19, 2003.
  1. Argento
    Argento
    I'm considering taking back my Limit dvd player - too many problems for 4 days!
    I want to get a philips963saPAL - but have a couple of questions:
    1. Can It play DVD-Audio or any SACD? (6.1 output)
    2. I'm I right in saying that you need a special remote to enter the Pal progessive hack?
    3. If so, can anyone tell me of a supplier of this player that sells it with both the Region free and pal prog hack already done...
    4. Does it have compent out?
    Thanks for your help folks.
    Richard
  2. Guest
    Sounds like you need to do some more research....
    Its SACD only, and SACD is 5.1, not 6.1
    No you are wrong. The PAL-P hack can be made with the remote that ships with the player.
    Machines with the new 7.1.11 firmware don't need the PAL-P hack - its enabled by default. Most supplies will be able to get you MR, if not DIY with a 4 in 1 Remote, or Pronto.
  3. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Puddleduck,
    Is there a simple way to check the firmware version of the machine, via the menus etc ?
    Thanks,
  4. Argento
    Argento
    Thanks Andy, The Home Theatre Forum says that It is DVD-A compatable......
    Rich
  5. Guest
    It will play DVD-A's if it has a Dolby Digital track (they play in ANY DVD player), but you won't be able to play the high-resolution Meridian encoded DVD-A content.
    If you want SACD and DVD-A you'd need a Universal player, like the Pioneer 656 for instance.
  6. Guest
    To check the firmare:
    Press the System Menu button. Navigate to the leftmost menuitem. Go to "Access Control -> Status Window -> Low Power Standby"
    Keep pressing the Down button and your firmware revision will pop up on your TV screen.
    If you don't have 7.1.11 firmware do this:
    to hack, PAL-P press "Play", "159 222 023 00", "Play" on your 963SA remote.
  7. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Deleted . . .
  8. Guest
    err.. thats why I just posted above!
  9. Argento
    Argento
    So, If I want pal & ntsc progressive, dts es & dd ex, dvd-a and SACD, multi-region, component output, 6.1 audio out - what DVD player should I get?
    Rich
  10. Guest
    I'm a bit confused by your talk of dts es & dd ex and 6.1 out.
    DTS-ES and DD-EX is 6.1 (well DD-EX is matrixed 5.1...) and ALL players will output this via its Digital Bitstream. You just need an amplifier that can decode this.
    If you mean 6.1 via Analogue Out (pre-decoded) then there ain't no such animal. 6.1 in the context of DVD-A and SACD makes no sense as its a 5.1 format.
    At the moment, there is no universal player that is PAL and NTSC progressive, and also does SACD and DVD-A.
  11. Guest
    BTW I agree with Limit is junk - I picked one up as a possible bedroom player, and I've never taken anything back to the store so quickly....
  12. Argento
    Argento
    How about if you skipped thje sacd.....
    Rich
  13. Guest
  14. Argento
    Argento
    OK - But the Philips DVD963SA can do pal & ntsc progressive, dts es & dd ex SACD, multi-region, component output, 5.1 audio out.
    Is this correct?
    If so, I will order one!
    Rich
  15. Dutch
    Dutch
    Dec 5, 2002
    2,580
    3
    North Yorkshire
    +263
    Yes!!
    Steve
  16. ebury
    ebury
    Nov 5, 2002
    1,250
    41
    london
    +12
    there is a universal player available from techtronics:pAL&ntsc prog,sacd,dvd-audio:pioneer 747(or at least they did-not sure about the 757i)
  17. Mark P
    Mark P
  18. Mark P
    Mark P
    sorry, i put my question in rich's quote
    can anybody point me in the direction of one of these?.....i'm after one but havn't located any yet.
    thanks mark.
  19. Mark P
    Mark P
    ok, thanks to some helpful forum members, especially tim, i have just about decided to purchase the PHILIPS 963a.
    a quick question please, the player is sold as region 2 only. i am aware it can be made multi region, but how?, is it a difficult job as i can't seem to find a handset hack.
    once that i'm sure it WILL be able to be made multi region i will put in an order. am i right in also thinking that it needs to also be programmed to output progressive scan?.....again how?
    any help much appreciated, i'm looking foward to joining the 963A club.
    thank mark.
  20. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    The hacks are in " Philips 963SA due for release in October " thread.
    See post by jonny m on page 17. ( or just search jonny m's posts ).
  21. dejongj
    dejongj
    Nice to see such a constructive statement. There are quite a lot of very happy Limit 9900SE owners. When you take a look on this and other forums you will see problems reported with the Philips as well.
    People are so impatient, when you have a problem get it fixed or exchange it but don't paint it all with the same brush....
