philips9617 and RGB - question for owners
Discussion in 'General TV Discussions Forum' started by arifn1, May 21, 2002.
  1. arifn1
    arifn1
    Hi the usual suspects
    I have an IXOS gold plated RGB scart between by Pioneer 444 DVD and EXT1 on my 28 - 9617. However the info details that appear top left say EXT1 CVBS, and indeed the other four EXTs also say CVBS. I have checked all connections and made sure the DVD setup is RGB - but the tele doesn't seem to identify it as such. My question is - do any of you get info that says EXT 1 RGB(or EXT 2 RGB if you have that one set up too) - or do I have a problem here?
    One of the pins in my scart is slightly bent - could that be the cause?
  2. nictry
    nictry
    Apr 28, 2002
    5,824
    Kent
    +652
    I have the 9607 and EXT 1 and 2 should both ne RGB with an RGB input, I think the Scart is almost certainly the problem as I had CVBS show up when my scart wasn't fully in the back of the Digibox, gave it a shove and hey presto RGB again.
    Hope that helps
  3. arifn1
    arifn1
    Thanks nictry
    I'll give it a shove when I get home! BTW - on another post you mentioned something called a THX Optimiser which you used to calibrate geometry etc. What is it? Ta
  4. nictry
    nictry
    Apr 28, 2002
    5,824
    Kent
    +652
    You can find it on 'some' DVDs their was an old version on T2 and I beileve it may also be on the Toy Story 2 and Star Wars EP1 DVD, the latest version is on the R1 release of From Hell and includes some new tests around colour settings etc.
    I am no expert on this but from reading the forums if you want to really calibrate your system then Avia seems to be the name mentioned although I understand it costs about £30 so may be the THX one would be the best bet first :)
  5. spikeyboyo
    spikeyboyo
    Just to confirm i get RGB on screen with both EXT 1 and 2 - using Sky and DvD.
    Spike
  6. arifn1
    arifn1
    I just took the Scart out and pushed it back in - and I got RGB! Doh...
    Not sure why it changed to CVBS in the first place -as I say one of the pins is slightly damaged but I hope it doesn't switch over again.
    Unfortuanatly my second EXT isn't RGB as its connected up to and ITV digital box
    cheers guys
