Philips WideScreen Problem
Discussion in 'General TV Discussions Forum' started by ]SK[, Sep 28, 2003.
  1. ]SK[
    ]SK[
    Right,
    After a lengthy period of use (Say 4 hrs) the TV's sound suddenly starts to flick between Stero and then Mono. Which basically stops all sound. In which time if you try to change channel the TV takes upto 5 minutes for it to change. If I switch the TV off and then back on I can hear the Demagnetize kicking in but its like 20x slower in switching on and off upon starting the TV. The only solution is to leave it for a few hrs and then come back to it, at which point its working fine again.
    Really puzzling this one. Ideas? If you want model number I can give it you but I cant find it in the dark just yet :)
