Philips vl1400 video sender
Discussion in 'Philips TVs Forum' started by cruncher75, May 23, 2005.
  1. cruncher75
    cruncher75
    Nov 1, 2003
    1,421
    southampton
    +117
    Hi i got one of these but cant seem to get the philips universal remote to work with my sky+ box (amstrad) or plasma anyone else have this prob.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It might be the IR being emitted by the plasma interfering. Any Philips universal should work it all. Just to check though, this is after sending the IR throught the sender I presume? Does the remote work directly, or is it just the sender? I have recently come across IR trouble with Amstrad boxes and QED roomlink. It works if you don't let it see too much of the emitters in that case, dont put the emitter right in front of the sky box, let it just see reflected IR, and try and shade both from the plasma, reflected or direct.
  3. cruncher75
    cruncher75
    Nov 1, 2003
    1,421
    southampton
    +117
    the sender works fine its just trying to set up the control dont seem to want to work anything it works the sender box ok
