Philips vl1400 video sender
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cruncher75, May 23, 2005.
  1. cruncher75
    cruncher75
    Nov 1, 2003
    1,406
    southampton
    +115
    Hi i got one of these but cant seem to get the philips universal remote to work with my sky+ box (amstrad) anyone else have this prob.
  2. Beancounter
    Beancounter
    Aug 22, 2004
    1,871
    +57
    I couldn't see any codes for either brands of Sky+ box when I got my videosender,it doesn't seem to like my DVD or PVR too so I ended up getting a Harmony 628 off ebay to work everything, was so good I bought a second for the bedroom too. :thumbsup:
  3. bbasra
    bbasra
    Sep 15, 2004
    1,622
    48
    Hounslow
    +41
    has anyone got the philips sender to work with Sky+ as i am having sky+ installed on thursday and would like it to work as i use this in the bedroom.
    this is a must have for me.......... :-(
  4. cruncher75
    cruncher75
    Nov 1, 2003
    1,406
    southampton
    +115
    yea all works fine just cant seem to get the universal remote to work with it so got another sky+ control insted
  5. bbasra
    bbasra
    Sep 15, 2004
    1,622
    48
    Hounslow
    +41
    how did you get to use your sky+ remote with the sender, i cant get my currenty sky remote to work with it, but the universal one does :rolleyes:
    if i can the sky one to work, that will be okay.
    TIA
  6. cruncher75
    cruncher75
    Nov 1, 2003
    1,406
    southampton
    +115
    have u pluged in the remote sensors u need to turn of the video sender before u do then plug it in the hold down a botton on ur sky control and move the sensor around in front of the sky box untill it changes channel
  7. verwood
    verwood
    I couldn't get the IR on my video sender to work - so I bought a Powermid to run alongside it.
    THe Powermid doesn't have to sit in front of the sky box, because you can use the IR extender (which comes with the Philips sender) on the powermid.
