Philips TV Teletext Problem
Discussion in 'General TV Discussions Forum' started by damienthorn, May 28, 2005.
  1. damienthorn
    damienthorn
    My first post here! :hiya:
    Bought a Philips 28 inch widescreen TV for my parents just a few months back. I forget the exact model number but when you access the teletext and then go back to TV screen the teletext resets and starts scrolling again for the page you selected. It's pretty annoying as you can't clear the text as you wait for the page. I hope I've explained that properly!
    Is this a fault with my set or just poor software on Philips' part?
    Thanks!
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    If its still in warranty it might need a new text module.Get an engineer out to have a look.
