Philips TV IR control codes
Discussion in 'General TV Discussions Forum' started by cbemoore, Sep 15, 2003.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,295
    38
    Esher
    +16
    On my Philips TV remote, the power button only switches the TV OFF, not ON. To switch it on, I have to press "Channel up" or "Channel down".
    According to the instruction manual, this is how its supposed to work. But I'd really like to be able to switch it on and off using the same button on my learning remote.
    Is there an IR code which will switch the TV both on and off? Or am I stuck with two separate buttons?
    (The TV is a Philips 32PW6332 widescreen).
    Chris
