Philips TV/DVD combo question
Discussion in 'General TV Discussions Forum' started by beastman, Apr 25, 2002.
  1. beastman
    beastman
    Jan 23, 2002
    79
    I like the look of the 28inch nicam set with built in DVD.
    28PW6816
    Philips also do a pro-logic model in the 28 & 32 inch 28/32PW6826.
    I was wondering if anyone can confirm that it is multiregion hackable. I have read from the excellent site/forum at www.dvd.reviewer.co.uk that it can be hacked using the Philips DVD 750 hack but it must be done blind as there is no DVD display.
    Any other comments or reviews of this TV would be appreciated.
  2. harijan
    harijan
    Jul 30, 2006
    2
    I am still looking to make my combo TV-DVD player region free. Any advice will ne most appreciated.
    thanks
    harijan
