philips tv crackling
Discussion in 'General TV Discussions Forum' started by gooner#14, Jul 28, 2005.
  1. gooner#14
    gooner#14
    Jul 18, 2005
    481
    hi bought a philips tv from dixons about a month ago model 28pw6518/05 and recentley its started a crackling noise from the back like a static noise is this normal??
  2. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, is it making this noise whilst its powering up or down or is it making the noise during normal operations ? If its the former then that is the eht 'coming up' (or going down) and by and large that's perfectly normal - it does sound like static. However, if its making the noise during normal operation then that's more unusual - it could be an indication that the eht is 'tracking' across a low resistance path inside the set, you might expect this on an 'old' telly since dust and dirt will provide a low resistance path - however as your telly is new that wont be the reason/cause. If in doubt, consult your retailer. Regards, yt.
