livello
Hello,
i've a Philips series 9000 32 " 32PFL9705k/02 that use the Sharp LK315DEGA33 lcd Matrix.
My screen has some problems but i can't find a LK315DEGA33 new or used to change.
i've found some similar panels like LK315DEGA13 and LK315DEGA23.
Do you know exactly the difference between the GA13,23 and 33? The only think that i've found is that probably the GA13 an 23 has a backligthing with lamp and GA 33 with LED.
So a could try to change the backligthing from lamp to led...but the other specification of the only screen matrix could be the same?
Thanks for any halp comments.
MAX
MAX
