Philips service menu - help needed
Discussion in 'TVs' started by jem, Jul 15, 2003.
  1. jem
    jem
    Sep 24, 2002
    527
    +7
    My Philips 6515 set seems to be missing a bit of the picture at the bottom having looked at the Thx test screen.
    I found a code for the service menu - 062596 i+
    Having looked at the web site with this code I've noticed that there are 4 vertical possibilities. Has anyone any idea what they mean?
    They are;
    V. Slope
    V. Shift
    V.Amplitude
    V S-Correction
  2. blindlemon
    blindlemon
    Just note the present settings and try them.... :devil:
    V-slope (I think) adjusts how much the picture gets enlarged as it goes down the screen. On my TV the top/bottom of the screen goes blank when I adjust this, but is restored when I move off the item.
    V-shift adjusts side-to-side centering
    V-Amplitude adjusts the height of the picture
    V-S-Correction adjusts how much the picture is "stretched" towards the top/bottom from a line across the centre of the screen.
