Philips RC9800i or Harmony 1000
Discussion in 'Home Cinema Control & Remote Controls' started by tabs, Jan 25, 2008.
  1. tabs
    tabs
    Apr 3, 2005
    1,974
    warks
    +129
    amazon are selling the phillips at £148.50 and it looks a nice unit ,,, which one though ... :confused:
  2. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    The Harmony. The Philips is flawed. It is only programmable within the remote itself, it does not come with pronto software that makes these remotes far more versatile & customisable. Your stuck with the screens provided but an extent I think you can add or remove an item from a screen.
    Do a search on this forum for the RC9800i it will unravel some rather dark "secrets" about it's functionality & why it should be avoided at all costs. I nearly bought one a few years back until I found out about it.
