Philips Q50 V Philips 962SA from Hivizone, any difference besides SACD playback
Discussion in 'Blu-ray & DVD Players & Recorders' started by brad123, Jul 4, 2002.
  1. brad123
    brad123
    Jan 29, 2002
    3,341
    68
    West Yorkshire
    +31
    I was thinking of getting thePhilips 962SA from Hivizone with PAL and NTSC progressive scan its $590.
    But then I saw the Philips Q50 for $468 that ALSO does progressive scan in PAL and NTSC.
    Now the only difference is that the more expensive one does SACD which im not really bothered about so will the DVD playback be the same on both these machines or will the more expensive 962SA be a higher picture quality also.
    Its to go into a Panny PTAE100 projector.
  2. jonny m
    jonny m
    Mar 22, 2002
    405
    from what ive read the 962 has the edge on picture quality. not sure how much of difference though.
