Hi, the TSU6000 is the RU970 and colour (Not the RU940 which is mono) so if you are asking the difference between the TSU6000 and RU970, there is hardly any difference but if you mean between the TSU6000 and RU940, there is a world of difference! (see the pics for starters - from left to right = TSU6000, RU970, RU940)
There is nothing stopping you using the TSU6000 here! The only problem you will have is that the RF is 418MHz rather than 433MHz so you have to use the US extender if you want to use the RF capabilities. (it is not strictly legal to use 418MHz here but.....)
The built in database is also more for the US market and won't have many european brands built in but 99% of people learn codes from their original remotes (note the learning eye is on the bottom of the remote by the connector, not at the front) or head to
www.remotecentral.com and look for CCFs with the codes in already!
Power cable available here
http://www.letsautomate.com/11154.cfm? at about £10 (search for Part No 10572 on the site).
Good luck
Stoobie
