Philips Pronto RU940 & Docking station
Discussion in 'Home Cinema Control & Remote Controls' started by wizbongre, Dec 7, 2003.
  1. wizbongre
    wizbongre
    Jun 24, 2003
    590
    Liverpool, Merseyside
    +63
    What would be a sensible price for the above second hand?
    Also, just how flexible are they? Is it simply a case of if I can get the original remote then the Pronto can learn the functions?
    Can I change the backgrounds/skins of this remote even though it is gray-scale? Can you make the touch screen buttons any shape/size in the editing software?
    Any known issues/bonus features I should be interested in?
    Also, how does it compare to the Marantz RC5000i?
    Thanks.
  2. Zone
    Zone
    Jun 24, 2001
    6,712
    Barnsley
    +2,389
  3. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
  4. wizbongre
    wizbongre
    Jun 24, 2003
    590
    +63
    Okay, thanks...
    Picked up an RU940 with docking station and rechargeable battery pack for £140 all in...
    Busy playing with ProntoEdit... :suicide:
  5. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    Sounds like you got a good deal!!
    Have fun on Pronto-Edit!!!:)
  6. wizbongre
    wizbongre
    Jun 24, 2003
    590
    +63
    Fun isn't the word!!
    Fortunately I've got most of the files I need from remotecentral.com...
    Just need to sort out the code for my freeview box.
  7. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    You have PM. BTW you'll find there's no such thing as a free lunch, remote central files will work, usually, but they often have so much other clag in them it's quicker and more straightforward to start fresh. I had a client who used a setup he'd downloaded, and had great fun, his lights went up and down with the channel select! He had a light control you taught a code to, and by a stunning coincidence it was the vol up on a hitachi plasma.
  8. wizbongre
    wizbongre
    Jun 24, 2003
    590
    +63
  9. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Cosmetically I'd agree! You can of course import new bitmaps etc, but then again you could start over...
  10. Sandman
    Sandman
    Nov 28, 2002
    3,492
    Glasgow
    +1,186
    Go to ebay.com (not co.uk) and search for philips pronto. There is usualy a few people selling serial cables that will do the job for you.
    I would suggest finding a complete configuration file you like the look of (check out Dale Crawford's work by searchin for "crawford's" in the files section of remote central) and then learning your remote codes to the buttons. I find this the easiest way to create ccf files that work.
